Brief Description: Varnish, glue false ribs, tank fit
Finished supergluing false ribs after cutting to fit with bandsaw, then put fillets of hysol on for permanent bond. Put second coat of epoxy varnish on ribs adjacent fuel tanks. Cut the lip on the right fuel tank to make it fit, and the same size as the left. Also removed some material from the tank lips where it sits on the spar reinforcement fitings.
