Moved the fuselage outside in preparation for wing rigging. Attached both wings on the level fuselage with the help of my daughter and set the sweep, dihedral, and washout of the wings by loosening the clamps on the spar strut attachments and moving them. A lot of re measuring and releveling. The digital level worked well but was difficult to hold up on the 4ft level. Drilled the wing attach bolt holes. Removed the wings and put the aircraft back inside.
