Finished tightening the fuel connections on the firewall stopping all the leaks. Finished up the shaping and drilling of the leading edge and trailing edge fairings on the wings. Painted them with primere and white paint. Installed the seats with their tape velcro holder strips. Drilled out the wingtip holes in the fiberglass and installed the tips. Installed the OAT probe in the right wing tip, you can see it near the back on the bottom. Installed the landing light and taxi light lenses after adjusting the taxi light aim point. Put nuts on the aileron control rods. Started the engine for the first time but could onlly get it to run for a few seconds each time I tried. The lane lights went out for each attempt, but were on when the engine shut down. I am assuming it is a fuel problem and will work that tomorrow. Pressure was good though and throttle position didn't affect it. Installed the right door after puting the door seal strip on.
