Cut and installed the lift strut fairings. Left a little wiggle room for the jury strut attachments that will have to be covered over later but the Monokote should so a good job. Used the remaining fairing material from the shorter strut to make the bottom go closer to the end. Turned out pretty well. Used more balsa wood to close off the ends. Should only need a couple of applications of superfil to make it look good. I plan on getting a 3d printer and making fairing for the struts later on. Sanded and polished one of the wingtips, but might not do the other. Didn't make it look much different for a lot of work. Moved some stuff to my hangar too.
