Worked on the glare shield attachments. Found it difficult to get the glare shield in with the tubing that is the front, but managed. Had one of the connectors come off while I was playing with it, and found that it was not screwed in. Glad it happened now, later will be a little harder to fix, but not much. Hysoled on the butt rib closeouts where the bottom of the wing meets the fuselage. Needs some work to close out the front and back, but that will wait till I put the wings on. Soldered the wiring for the glare shield lighting, and tested it. The sides are too visible, but it works and looks very good. The dimmer doesn't turn all the way off and it is backwards though. Will have to talk to the manufacturer.
