Finished up the forward attachments on the glare shield and drilled all the mounting holes. Then I prepped it and used spray adhesive to glue on the suede covering. Turned out pretty good. I then split a 4 ft piece of hose and used adhesive caulk to bond it to the front of the glare shield. I will install the strip lights right behind the hose. It is looking good, but I didn't get a pic in the aircraft. I then glued on the synergy suede to the seat pans and the center console. I let it overhang the slots for the rudder pedal adjustment and the flaps so it would keep dirt out a little.
