Removed a couple of monitors from the display that I won't be using like pitot heat status and flap position. Tried to find out why the oil pressure and temp don't display, but will have to ask Dynon tomorrow. Also will ask if I can set the base temp on the engine probes because they are off a bit. Might all be fixed when I hook up the ADAHARS and the EFIS gets temperature and pressure readings. Finished the wiring harness end hook ups for the Com. Wired the battery status wire for the Earth X battery, but didn't get it to show on the display yet. Lots of questions for Dynon. Lots of learning about the EFIS to go before flight. I can't even straighten up the wires until I make sure everything works. I also need to put in another in line fuse or two.
