Brief Description: Got the Prop, Master, ELT Speaker
I finally got the prop today. It came from Airmaster in New Zeland. Constant speed electrically adjusted three blade. Looks great. I installed the ELT speaker on a cross member above the left avionics bay. I think the zip ties will work permanently. Made a length of 18ga wire and ran it from the master switch to the solenoid. Made up two diodes for the master solenoid and the starter solenoid to prevent voltage spikes upon shutdown. Getting pretty busy up front.
