Planning the layout and installing the boxes on the avionics trays and in the bottom of the fuselage. Put the main display and the radio control head, and the intercom control head in the panel along with most of the switches to get a feel for the wiring. Mounted the radio transciever in the back behind the pilot's seat on the side abeam the baggage compartmen, you can just make it out in the upper right of the picture.. Found out from Dynon that I need to make my own wire harness for that, so I can mount it anywhere. Hysoled in the plate for the ADAHARS with nutplates riveted on the back. Ran the wiring for the intercom from the control head to the plugs behind the seats. Mounted the engine monitoring module on the left avionics tray, and the display back up battery on the ground connections on the right side. I will use a bolt through the firewall for a ground.
