Finished up the firesleeve on the fuel lines and torqued them down. Installed the ECU on it's own little shelp behind the instrument panel. The bolt goes through an adell clamp and took me a long time to get in right. Little things slow me down. Then I went over my design of the panel. I tried a layout that has most of the switched in the center of the panel. I don't know if I like that layout or not. Might try the original way tomorrow, and I might even start drillin and cutting it. John from Kitfox sent me a picture of where they put the ambient air sensor, so I thing I have all the firewall forward pretty much fiqured out now. Still need to zip tie everything together.
