Worked on the radiator mounts and placement in the bottom of the cowling. I determined the bottom half of the engine cowling is fitting pretty good, so measuring I measured it for the NACA inlet scoop and the radiator. Started cutting the brackets for the radiator out of stainless. Tough stuff to drill or cut. I used the dremmel til the collar broke, then went to the air cut off wheeel. The black thing is the oil cooler that mounts in front of the radiator. Tomorrow.
