Covered the rudder and then heat shrunk everything to 350 degrees. Then it was on to the fuselage tapes. Started on the bottom, where there are a lot of tapes required. They go over every area that has structure underneath that will contact the fabric. There are also reinforcements where anything comes through the fabric and over some of the tape joints on the bottom. Lots of work.
