Got help from Fred and flipped the fuselage upside down to begin covering the bottom. Using the Eko Bond is so much easier and non toxic than the Poly Fiber method. I brushed the perimeter, then layed the fabric in the dry Eko Bond for a temporary hold. I then used an iron to tack it better then cut to shape. I then ironed the edges around the tubing then brushed a coat over the edges. Then I used the iron again to make sure the glue is holding everywhere and also to shape the fabric around the tubes. It is a much easier system that leaves a better surface and doesn't kill me.
