Brief Description: Final tail coat, first wing coat.
Sanded and cleaned the top of the horizontal stab, elevator and the right side of the rudder for the second coat. It went on fairly thick, but the pressure was less this time. Not much of a change. They came out pretty good, but I think I will do a final buffing before waxing them. After they dried, Ted help me move them out of the way and I sanded the left wing with scotchbrite and cleaned with a wet rag and the air compressor. The first coat went on really fast, and since it was in the rotisserie, I did both sides. Had a little running that I touched up with a foam brush but the paint flowed out well with minimal brush strokes. After sanding for the second coat, it will not be noticeable. I have been working on the baggage compartment in while waiting for the paint to dry, and it is done except for one attachment point. Lots of sewing.
