Finished heat shrinking the rudder and then started the two coats of polybrush that goes on the tail before the tapes. I brushed on the inspection covers and the gas cap doilie too. Took a while but I finished it all and then went to work on the tapes for the elevator bottom. Just got one side done with the 1 inch tapes. Looks good with just 1 inch tapes so I will see how much I can get done with the remainder of my 1 inch tape. Last pictue is blurry. Will try to replace it later.
