Stitched all the ribs on the right wing in one day. Including putting the tapes on the fabric over the ribs to keep the stitches from cutting the fabric. Lots of work, but it went faster than the left wing. Took a picture of the magnetometer mount. Still need to put varnish on it and attach the 4th stop on the dowel rod. The mount has to be non magnetic for the sensor out in the wingtip. Did a little bit of heat smoothing too. This wing has more wrinkles that need to be ironed out than the left wing. Thought I would get better with practice.
