Finished prepping the left wing and then began covering. Got the bottom glued on all around and trimmed to fit. I learned that MEK eats through my crappy vinyl gloves pretty quickly. I used the small hobby iron to smooth out the wrinkles in the glued area around the edge on low heat. Amanda helped me turn it over and I started prepping for the top covering. Came out after dinner and worked on the pitot tube installation for about an hour.
