I cut and bent the pitot static lines coming out of the pitot tube to fit inside the wing and also go through the pitot mast without interference in case it needs to come out some day. I will make an inspection hole near the tube. I then went to work calibrating my big iron and the small model aircraft covering iron used for detail work. I found out that the non contact IR thermometer will not read accurately on the big iron's reflective surface. The smaller one has a teflon surface, so it worked ok, but the contact thermometer did not show the same readings. I messed around with them for some time before setting the temperature marks for 225, 250, 325 and 350 degrees. I will have to check them again before use.
