Worked on the pitot tube mount today. Hysoled it into the wing and even got the first coat of epoxy varnish on it. Got screws for the mast and drilled out the holes and tapped the holes in the top to compliment the lock nuts. Ran the wiring for the wing tip landing lights and the strobe/position lights through the rear spar in corregated wire protective wrap. Ran the pitot and static lines, along with the power wires for the pitot tube along the rear of the fuel tank and through the ribs. Used waxed wire tying cord to hold in place, along with some sealant for the area behind the tank. Put a coat of varnish on the floor boards, second for the back two. Made a mount for the tail beacon that will allow the wire to run inside it and not be seen, and also to screw into the tail.
