ROBERT'S WEB SITE
Date:  1-26-2018
Number of Hours:  4.00
Brief Description:  Doors again
A littl more sanding today and the right side door looks good. Drilled the holes in the hinges and then match drilled the acrylic. Used a smaller drill bit and clecoed in place to check the fit. Will need to make the holes bigger and bolt on the hinges. Lots of checkin and re checking to make sure the first holes are right.
