Sanded more superfil today. Lots of sanding. The wingtips are pretty much ready for paint. I drilled out the wingtip strobe/position light holes and mounts and am ready to put them up for a while. I drilled holes for the tail beacon light on top of the vertical stabilizer too. I also drilled lightening holes in the aft two baggage compartment floors since the compartment sack will rest on top of them, and the weight can't be much. I installed the horizontal stabilizer and hysoled the trim position indicator tab too. You can see the position indicator in the second picture. Busy day, but not many pics.
