Cut the aluminum longerons and shaped the ends to fit the fuselage tubing with files. Cut and shaped the bottom longeron to fit inside the square tube on the front end. Drilled the side longeron brackets into the longerons and clecoed. Worked on the cockpit floorboards and their clearance from the rudder cables.
