Double swaged the rudder cable eyes and connections starting with the cheaper swager I have, to hold them in place using the vice to hold it. Then I used the better cutter like swager that Ted loaned me to make two swages in each one. Clamped the control horn on the rudder to hold for fitting and used a board to hold the pedals. The rudder horn will be swaged after covering. All swages were covered with heat shirnk tubing.
