Installed the elevator control rods and bellcranks to the tail. Installed the flap/aileron mixing unit and all the press fit bushing associated with it. Made pin restrainers out of stock aluminun and installed with clecos for now after primering. Safety wired the bolts attaching the unit to the fuselage. Drille a 1/16th hole the the flap detent pin, with considerabel effort and after several broken drill bits, and then installed the flap handle and control tubes. Test fit the floor boards. Still smoothing the elevator feel, with lots of time spent there.
