Cut and sanded down the landing light lense to fit the wingtip. Cut out and bent the landing light aluminum mounts for both wings and test fit to the right wing. Drilled and clecoed the lense in place, Used superfill to fill in holes and gaps in the leading edge and smooth other areas. Started trimming the wingtip standoff mount for the position/strobe lights.
