Brief Description: WIngtip Mounts, Landing light mount
Cut all the aluminum strips for the wing tip attachments, and drilled and deburred them after removal. They will be bonded and riveted after covering of the wings. Made an aluminum mock up of the landing light mount I designed, and test fit it on the last rib. Used a fly cutter to make the large hole,
