Fitted and prepped flaperon plastic tips and end of flaperon. Fitted, drilled and prepped number one rib and then bonded all and riveted the ribs. Cut the back of the flaperon to match the tip angle. Drilled control horn fittings, and cut and sanded nylon bearings. Drilled and cut lock ring. Riveted the last two solid rivets into the trailing edge after trimming.
