Brief Description: Tank Hysol, wing corrosion proof
I put the fillet of hysol between the wing tanks and ribs in the morning, then Fred came over in the afternoon so I used him to help flush the wings with denatured alcohol. I then decide to use my can of zinc chromate to corrosion proof the inside of the spars since they would not come into contact with the covering chemicals. I took a shop vac and taped it to one end then sprayed the zinc chromate into the other end of the spar. I did this to both ends of each spar and got remarkably good coverage throughout. I will use this technique with the corrosion x when I have the aircraft together every year to make sure they stay corrosion free. Amand and Lori helped today too. I also prepped for the corrosion proofing of the outside of the spars. I will do this before installing the Laker Leading edge fiberglass, so I can cover as much as possible, even under the leading edge, so I taped the area where the hysol will go since bare metal makes a better bond.
