Notched bothe #1 ribs to fit over the spar reinforcements. Reamed the jury struts to size. Installed the wings again and filed the attachments on the aircraft to fit the spars with the reinforcements. Bonded the #1 ribs in place.Re rigged the wings. Installed the jury struts with clamps and marked and drilled the spar attachments for them after they were rigged. Drilled and clecoed the Butt Rib closeouts. Thanks for the help moving and holding things from my daughter, and my neighbor Daniel.
