Make washers for nose gear. (Didn't realize I had them.) Cut bushings for main gear axle. Fit engine mount and cut shims. Clamp, drill, debur, bolt. Only need to countersink. (Gotta buy the bit.) P32 now done. Ream and press bushings for dual control stick C05. Fit horn assembly.
