Richards Web Site
Date:  12-24-2005
Manual Reference:  P14
Brief Description:  Battery box
The battery box is sized to fit the standard Odyssey 625 battery. Like others, I added piano hinges to make access easier. It will have a thin layer of foam on the inside, so I opted to rivet the hinges from the outside. The bottom piano hinge has a tab where I'll add safety wire for the pin.I decided to add a reinforcement doubler on the inside. The battery is heavy and the firewall really flexes under the weight. It's probably unnecessary.
Reinforcement doubler on inside
All buttoned up.
All buttoned up.
