I'm using Kuntzleman strobe heads. I wired the right side strobe cable. I used a common trailer disconnect fitting to make it detachable at the wing root. The heads come with a plastic block for fastening to a tube. I didn't need that, but I did need to make some sort of wedge angle so the heads would be more horizontal when attached to the slanted wing tips. I bondo'd in the tubular part of the bracket, making it flat. I added locknuts next...
