The panel connection were starting to resemble a rat's nest. I also wanted to be able to easily disconnect the panel if needed, so I redid the terminations and cabling, using Molex connectors from Radio Shack. With the exception of the main bus cable, p-leads, and the starter wire, all other wires are now on Molex connectors located on the left of the panel. The panel is now almost "finished". I do need to add one more Molex connector to the headphone jack sub-panel which mounts under the transponder. (It's hanging down in the second photo.)
