Worked on a few odds and ends today. I realigned the nose gear a bit, and readjusted the rudder tension on the right side, as the rudder was kicked a bit to the left when the pedals were neutral. I epoxied a rivet without the mandrel into the cowling near the air intake. This gives me a good way to safety the piano rod in place. There have been a few reports of this pin working its way loose, and into the prop. Not a good thing.
