Richards Web Site
Date:  7-22-2006
Number of Hours:  8.00
Brief Description:  Panel wiring cont'd
More wiring to the panel. The second photo is my homemade comm antenna. It's a female bulkhead connector and piano hinge wire. It will mount on the glare shield forward of the windshield bow. I also remade the fuel shutoff pull rod. When I made the first one I forgot to clear the transponder. I switched to steel brake line for the rod, rather than aluminum. The angles are pretty severe, so the extra strength is needed. The round knob is from McMaster Carr. It will mount right above the transponder on the panel.
Comm antenna
Comm antenna
Fuel shutoff control
