Slowly the various electric and avionics are coming together. The Andair fuel pump installation is now complete, the avionics worked though there was a moment of panic until I realised the master switch needed turning on as well as the avionics master switch. The P-Mags are vulnerable to heat over 200 deg F, a heat sticker has been placed on each one and a blast tube will be fitting as per the suggestion in the installation instructions.
