Robin's RV8 Web Site
RV8
Engine / Fuel Parts
6-14-2014
Engine Layout 3
General layout of the port side of the engine, note the oil cooler is set back at 15% to allow cooling air to the forward bottom side; the engine run-up on a day with 27deg outside temperature resulted in a max. CHT 365 deg. F.
Port forward
Port side
Port rear
RV8 Home
329
Ailerons
Avionics & Electrics
Engine / Fuel Parts
Fairings
Finishing
Firewall
Flaps
92
General
James Cowling
Landing Gear box Ass
Misc. Parts/Hardware
Oxygen
Painting/Corrosion
Testing & Setups
Wing Tanks
