Robin's RV8 Web Site
Date:  5-27-2013
Number of Hours:  1.00
Manual Reference:  M.P. Sender
Brief Description:  E-Mag M.P. sender Manifold
The Manifold Pressure for the P-Mags is taken off the Sender Manifold using a modified AN fitting tapped to accepted a nipple; Loctite 270 was used on the nipple thread. A Festo ‘T’ piece allows M.P. feed to both P-Mags. All fitting are model Jet aircraft fuel hardware and these are required to stop any air leaks in the fuel line to jet engines which would cause an engine failure; they are of excellent quality.
AN fitting & Nipple
AN fitting & Nipple
Nipple & Festo 'T'
Nipple & Festo 'T'
Festo 'T' piece
Festo 'T' piece
