Robin's RV8 Web Site
Date:  11-11-2012
Number of Hours:  1.00
Manual Reference:  DWG 75
Brief Description:  U/C connecting Brake Lime
The pipe to connect the brake line between the undercarriage leg and the fuselage was most difficult. Please Vans you need to redesign this area. Eventually, after several attempts a good pipe protected with spiral wrap was constructed. The connection to the fuselage was made first with the pipe away from the U/C connection to gain enough room to work, then the final adjustment to the pipe was made to marry it up to the U/C leg connector which with a crowfoot and universal joint adaptors was made with ease.
Brake Pipe Fus/UC
Brake Pipe Fus/UC
