Robin's RV8 Web Site
Date:  7-1-2014
Number of Hours:  1.00
Manual Reference:  ?????
Brief Description:  Aileron Stops
The Vans’ Aileron stops seem difficult to assemble accurately whereas the some builders have used a Teflon stop on the control rod. These look simple and accurate to manufacture and assemble.
A Teflon rod was drilled and a thick wall tube inserted to give good wear and stop the Teflon being crushed. Remarkably, once assemble the range of movement of the aileron came out perfect to 0.1 degree without any alteration.
Aileron Flap Stop
Aileron Flap Stop
Teflon Rod Drilling
Teflon Rod Drilling
Thick Walled Insert
Thick Walled Insert
