Robin's RV8 Web Site
Date:  5-8-2011
Number of Hours:  1.00
Brief Description:  Paints, Alocrom & Cleaner
Deoxidine 624
A brush applied acid cleaner for use on aluminium and its alloys prior to painting or Alocrom treatment.
Alocrom 1200B
A rapid process which forms a protective golden coloured conversion coating on aluminium and its alloys. Outside the UK, the Alocrom ranges of products are marketed under the Alodine trade name.
CM0481968 is a high performance, low VOC, two-component, corrosion inhibitive
Epoxy Primer and Surfacer that contains no chromate. This high performance
Epoxy primer is intended for use on all types of aircraft and has excellent
recoat/intercoat adhesion with Sherwin-Williams topcoat systems
Brilliant but expensive.
Deoxidine 624
Deoxidine 624
Alocrom 1200A & B
Alocrom 1200A & B
Epoxy Primer CM0481968
