Robin's RV8 Web Site
Date:  7-28-2014
Number of Hours:  1.00
Manual Reference:  Magnetometer
Brief Description:  Magnetometer Mount Installation
The Magnetometer was installed using a Garmin Lancair IV mount on the Stab. wing which is the electrical quite wing; the pitot heated tube, OAT sensor are installed on the Port wing. Also, the earth to the Wing Tip LEDs is not connected through the wing but through the foil sleeve of the 20awg LED wire as per the instructions. The Garmin instructions were most carefully followed including the calls for the wiring ties.
Magnetometer Mount
Magnetometer Mount
Magnetometer wiring
Magnetometer wiring
Magnetometer
Magnetometer
