Robin's RV8 Web Site
Date:  6-22-2011
Number of Hours:  1.00
Manual Reference:  DWG 3 & 4
Brief Description:  Closing off the fiberglass tips
A double sided laminate of 1/4 foam is let into the tips. Two laminates are used on both sides. A resin glue is made using polyester resin, Cabsol and milled fibres for attaching the laminate. The process copies a Glasair procedure for closing off their tips. The outside surface was coated with a gel coat to give a smooth finish.
H. Stabilizer tip
H. Stabilizer tip
H. Stabilizer tip
H. Stabilizer tip
V. Stabilizer tip
V. Stabilizer tip
