A ‘Fairing Inc’ Wing Root Fairing was used, it required some considerable time to fit and install but the end result was pleasing. The two outboard holes of the undercarriage cover were used as well as two other holes either side to secure the fairing. It took four primer coats and pin hole filler to achieve a good finish.
