The underneath of the Forward Wing Root Fairing gap seal was simple but making the rear to conform to the underside required the edges to be rolled carefully; an extra screw hole was installed at the rear; this kept the rear tight to the underside. A hole was made using an ‘unidrill’ to access the wing installed gascolators.
