Two pieces of Aluminium right angled were matched drilled to the width of the spats. These were cleoced to the front and rear. Foam blocks were added to the rear and front. Perfect…so all the spat attachment holes were drilled. The whole thing was then checked with a plumb line. Finally, a cabsol epoxy was used to produce a shim for the attachment points.
