Robin's RV8 Web Site
RV8
Oil Cooler
Oil Cooler 2.
The Oil Cooler with the 15deg offset allows more room and airflow behind cylinder #4 and plenty of space between the Oil Cooler and the engine mount. The hardwareis quite tight to the cowlings though the gap is 0.46” as measured using Play-Doh!
Oil Cooler
Oil Cooler / Mount
Cooler fitting
RV8 Home
329
Ailerons
Avionics & Electrics
Engine / Fuel Parts
Fairings
Finishing
Firewall
Flaps
92
General
James Cowling
Landing Gear box Ass
Misc. Parts/Hardware
Oxygen
Painting/Corrosion
Testing & Setups
Wing Tanks
