Beware the change in line of the cowl at the bottom of the luggage door, it is a catch you out and it caught me out! The Balsa wood spacer between the spinner and the front of the cowl worked well. The final gap was about spot on with the Spinner about 1/8” higher than the cowl. This allows for a slight drop in the spinner for the engine to beds into the Lord mounts.
