The final Andair fuel pump installation is as simple as possible to aid maintenance. The Andair fuel Gascolators which are installed on the fuselage side in line with the wing tanks means that no other fuel filters are required after the fuel pump. Andy, the owner of Andair, prefers this setup which filters the fuel upstream of the fuel selector and pump. Also, this position of the Gascolators should be cooler than on the firewall.
