Brief Description: Clamping and Drilling the top Loneron
The Longeron was carefully clamped vetically and horizontally to the engine mount xxx and the skin. The Engine xxx was drilled first contary to the instructions since this part seemed more rigid. Rocol RTD liquid was used to drill the steel Weldment engine mount and stronger English xxx clecos were use to clamp the drilled parts.
The Avery xxx Tool used for drilling the Longerons at right angles was brilliant and ensured accurate drilling.
